Hello!
Using the Ensley template, I get an error whilst performing the demo installation. See attached image.
Same issue occured in other templates also. Please see attached URL.
Playing around with PHP settings didn't fix the issue. Can you give it a look?
Many thanks,
Robert
- kleinpeter
- Tuesday, 23 January 2024
I have just updated to the latest Joomla version and rebuilt the demo installer for this template and all appears to be now working correctly. To obtain simply re-download from your template downloads.
My apologies, could I ask you to try again with a fresh download of the template demo installer?
Thank you Tina
The issue should also now be resolved with the latest download of the Naomi template.
No problem Ciaran. Everything is working fine. We all know we can rely on you. Quick help, thanks for that.
Hi Ciaran, the Naomi template is now also causing problems...
- # 13
Thanks Ciaran,
now Naomi has a different problem.
Duplicate entry...
Duplicate entry...
- # 14
I have the same problem ( Call to a member function load() on null) with Novah.
Please help.
Pieter
Please help.
Pieter
- # 15
I have just updated the Novah template demo installer to resolve this issue.
- # 16
I may have been a little premature. I got an error (Duplicate entry '700-4.4.0-2023-09-13' for key 'PRIMARY). It looks the site (frontside) is working. But the admin side isn't.
- # 18
After entering the setup details and pressing the "Install Joomla" button. It looks like things are getting installed (spinning Joomla logo), but the page remains unchanged (apart from the error message). When I check the site url in another window I get the "Congratulations page". Front end and back end look correct, but I can not log in. No user is created.
Also see https://www.joomla51.com/forum/j51-layla-template-demo-does-not-work-on-xampp#reply-49924
- # 20
- 2
