1. mhp
  3. Tuesday, 27 August 2024
I've installed EMANI in a J-5.1.3 and need to change the template preset to 'style 4'.
I can choose and load it in the template-style options but after the reload it switches back to 'standard' and nothing has changed layout-wise on the site.
Any hint what could be wrong there?
Roger
  1. https://neu.swisshistotech.ch/de/histo-newsletter
Hello Ciaran
Sorry for the delay.
Yes, Image-Class was empty but it took it from global options ('left').
I deleted it from the global options and now it's fine.
Thank you for your patiience, regards
Roger
Is there a folder with the name "presets"?
If not, the installation of the template was incomplete. You van copy the folder from the installation file into "Templates/j51-emani/ (with FTP)
The presets are all there and chooseable:
https://prnt.sc/zMGwAQYQMFjA
Can I override this in the template-style params in the database?
Would that be enough to switch the template to a certain style?
That would speed things up as manipulating DB-tables is easy for me.
you could always rename the files. style 4 to default and the present default something else
I renamed the files, but with no effect (Style_4.json is now Default.json):
https://prnt.sc/Rur_XVhf3jyK
Sure, access is sent by mail - thank you
Roger
Updating your template to the latest download appears to have resolved the issue.
Thanks.
But to me it seems the behavior in the backend is still the same.
But thats ok for now.
The main difference between our site and the demo is the blog detail view:
https://neu.swisshistotech.ch/de/histo-newsletter/150-erster-blogeintrag-platzhalter
vs.
https://www.joomla51.com/demo/0172/index.php/blog/114-mauris-ligula-justo
Do you know what is the difference here and what to do that these looks the same?
(Image above the text)
Is this preset- or layout-related (through the menu item options)?
Roger
Hi Roger
You are still unable to load the preset template styles? We created a temp template style and were able to load the presets without any issue. You are unable to replicate this?
Hello Ciaran
The template styles seems to load correctly now - thank you very much.
The only thing left is the thing with the blog detail-view (above).
It would be cool if you have a hint for me how I can achieve this - like on the templates demo site
Have a great weekend
Roger
Hi Roger
Have you set an image for your article? Ensure that you have set an image in the Images and Links tab of your article and that the Image Class field is left blank.
