When i make submenues for position (header3) the display not work.
.header-3 .active > a {
color: var(--primary) !important;
}.module .mod-list > li.active > a {
color: var(--primary);
sidecol-a, .sidecol-b .mod-list > li.active > a {
.sidecol-2b .mod-list > li.active > a {
.j51imagehover148 .j51imghvr-item {
padding: 0px 5px;
1. May we misunderstand your request. When we navigate to Aktuell -> Stellenangebote, the 'Stellenangebote' menu item in the side column menu is displayed in pink (tested in Chrome and Firefox). Is this correct?
- No not the menu "Aktuell" but the menu from header-3 "Über uns" and then the side menu in Sidecol. If you click on a menu entry (active) there was not pink.
2. To increase the spacing between items in your Imagehover module you can use the Horizontal Margin and Vertical Margin fields in your module settings.
I tried that yesterday but it did not work. Now it seems to work.
.module .mod-list > li.active > a,
.module .mod-list > li.current > a {
