1. SYSOPONLINE
  4. Wednesday, 03 June 2020
Problems with Template Natalie.
When i make submenues for position (header3) the display not work.
Thank you.
These issues should be now resolved.
Thank you for detailing. To amend replace your custom CSS with the following....
.module .mod-list > li.active > a,
.module .mod-list > li.current > a {
color: var(--primary);
Thank you so much. Now it works all fine!
It seems that the template has some errors.
It does not matter if you turn stickyheader on or off. The menu bar does not stop.
The news component like in Example 4 does not work either.
i add only 2 news files
Attachments (3)
Thank you for bringing this issue to our attention. Updating your template to the latest download should resolve this issue for you. For details on updating your template may I suggest the following article.. https://joomla51.com/tutorials/joomla-basics/updating-your-joomla-template
I updated the Template an News component. But it doesnt work. I send you a login to [email protected]
Only the submenu works now. The Sticky header and 2 articel carousel in news component doesnt work.
Thanks most of it works now. I only have the problem that I created the menu item from header 3 as a side menu, but the active post is not marked.
from normal Menü works
from header3 Menü doesent work
My apologies but could I ask you to resend access details to your site to [email protected]. We appear to have discarded them.
This should work for you. To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)....
.header-3 .active > a {
color: var(--primary) !important;
i addet the code but the highlight of the sidemenu (sidecol Menu) doesent work. I send you the login data.
Highlight on .hornav and -header3 works fine.
Sorry ciaran but the fade effects (animate fadeInLeft etc.) in mod_j51icons doesent work too :(
To apply to all menus you can use the following CSS instead..
.module .mod-list > li.active > a {
Would you have a URL directly to an example of your icons module?
hello ciaran,
the code
doesent work for the sidecol-2b
I have added the following to custom.css:
sidecol-a, .sidecol-b .mod-list > li.active > a {
or
.sidecol-2b .mod-list > li.active > a {
neither of which works.
I also try to increase the distances between the images (J51 - ImageHover Gallery). Unfortunately this does not work either :(
i want a padding from 5-10px
I tried it with this code.
.j51imagehover148 .j51imghvr-item {
padding: 0px 5px;
i send you the userdata to [email protected]
1. May we misunderstand your request. When we navigate to Aktuell -> Stellenangebote, the 'Stellenangebote' menu item in the side column menu is displayed in pink (tested in Chrome and Firefox). Is this correct?
2. To increase the spacing between items in your Imagehover module you can use the Horizontal Margin and Vertical Margin fields in your module settings.
- No not the menu "Aktuell" but the menu from header-3 "Über uns" and then the side menu in Sidecol. If you click on a menu entry (active) there was not pink.
I tried that yesterday but it did not work. Now it seems to work.
Great... thank you for the update!
