If this is still an issue, you can send temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
I am not sure copying the site will resolve the issue. It really depends which parts you intend to copy.
A couple of things to try...
1. Uninstall any components/plugins/modules that you are not using.
2. Navigate to Extensions -> Manage -> Database and check for any errors. If errors exist try using the Fix option.
3. Navigate to Extensions -> Manage -> Discover -> Discover. Are there any extensions found?
Sorry to say I am unable to find a solution to this issue. As the issue is not template related, I'm probably not the best person to be looking at it.
I can find no reference of similar issues so may be, as you say, an issue with your local installation. It would be interesting to see if the issue still exists if you copy just the database to a fresh Joomla install.
