I have added the snippets below to the custom css of a Chelsea website. None of them seem to work. When I change the body font-size, only the distance between the line change, not the size of the fornt.
Can you help?
Kind regards, Wouter
.j51imagehover_caption {
font-size: 20px;
.hornav .parent > ul > li > a {
font-size: 18px;
body {
font-size: 12px !important;
- Turkenburg
- Monday, 08 June 2020
https://historyofjazzineurope.eu/
I switched to the Noah template this morning: same problem.
Thanks for looking into the problem.
Hello Wouter, hallo Wouter,
When i'm looking on your site with style-editor, I see that the font-size for p is 12pt instead of 12px. Did you perhaps make a typo? Can this be the problem?
Regards, Geert
Regards, Geert
Hi Wouter
I am not seeing your custom CSS in your website source. May I suggest sending temporary administration access to your Joomla installation to info@joomla51.com and we will examine this issue further. For our reference please paste a link to this post in your email.
Dear Geert,
In my inspector I see px and not pt. Are we looking at the same?
Dear Cairan, I will sent the access to info.
Thanks, Wouter
Thanks, Wouter
On inspection, I realise your custom CSS is indeed been added without issue. I believe the problem is related to what Geert has mentioned. Each paragraph of text appears to have font-siize: 12pt applied inline to the element which is overriding the CSS in your custom CSS field. This is most likely been applied by your editor. Your editor should allow you to remove the inline sizing and therefore use the size in your custom CSS.
Dear Ciaran,
You write:
Where can I find 'my editor' ? How can I make my editor allow me to remove the 'inline sizing' ? (What is that anyway?)
As you can see, I am fairly new to this.
Thanks for the help. We are getting close solving the problem.
Wouter
You write:
Wouter
Hi Wouter
Inline styling is when styling is applied directly to an HTML element (instead of from a stylesheet). An example would look like the following...
When styling is applied this way it will normally override any other styling. Sometimes this is done by your article editor. You can select your editor your Joomla global configuration. Another possibility is that this content was copy and pasted from outside of Joomla and the inline styling got copied with it?
<p style="font-size: 12pt;">Some example text.</p>
Dear Ciaran,
Thanks for the explanation. So the editor (JCE) overrides the custom css. I did not know that; did not know that this was called 'inline styling'. I took out all the codes and now the custom css is effective in the article. Thanks for your patience and good help. Issue solved.
- # 9
