I want to force a template width for everything; headers, modules, background images, etc. Is there something I could put into the custom code CSS section to do this? Right now I am working with Valencia, however, I want to do this with others as well and the CSS seems very similar amongst them all.
Thank you,
Jason
Control template width?
- Issue
- jasonbrinn
- Monday, 23 January 2017
Fairmaxx is correct.
Essentially I want to setup templates like Valencia with a boxed framework.
At least I want to be able to control the background image width for each module and I am not sure what CSS controls it.
Thank you,
Jason
Thank you,
Jason
I think, it is analog to Jason's topic and question:
I can control the template width in the setting Layout Option.
It works fine.
But it's of no effect for the navbar and header.
(They stay in full-size)
But they should have the same width like my template width.
Michael
It works fine.
Michael
Hi Jason
Presuming I understand you correctly, for the majority of our templates a template width can be set within the 'Layout Options' tab of your templates parameters... https://www.joomla51.com/tutorials/item/editing-the-template-width
To amend the width of the header and showcase area of your template to match that of your template wrapper try adding the following to the Custom CSS field of your templates parameters where 1140px is the width set in your templates parameters...
#container_header .wrapper960, #slideshow {
width: 1140px;
#slideshow {
margin: 0 auto;
}Ciarán
Hello Ciarán,
the custom.css works just after input an additional line in the style.php:
$document->addStyleSheet('templates/'.$this->template.'/css/custom.css');
My template-width is set with 1140 px.
My custom.css now:
#container_header .wrapper960, #slideshow, #header {
width: 1120px;
margin: 0 auto;
So the header looks good. (with 20px less than the template-width)
But the left margin of the slideshow isn´t correct !!!
I tried to operate with margin-parameters, but I can't find the correct adjustment.
Michael
My custom.css now:
width: 1120px;
margin: 0 auto;
Michael
The content of your custom.css appears to be the following...
Try changing to the following...
Rather than using addStyleSheet, an option should be available in your templates parameters to load your custom.css
#container_header .wrapper960, #header {
width: 1140px;
margin: 0 auto;
} Try changing to the following...
#container_header .wrapper960, #header, #slideshow {
width: 1140px;
#slideshow {
margin: 0 auto;
} Rather than using addStyleSheet, an option should be available in your templates parameters to load your custom.css
thank you, good support an nice template
another problem:
the contact form induced an error 505 in case of sending an message.
the reply to the sender works.
can you help me?
(co-flexpersonal.de)
Michael
another problem:
can you help me?
Michael
Hi Michael
Sorry to say this would not be a template related issue. May I suggest posting your query to the Joomla forums where they would be better placed to offer assistance (https://forum.joomla.org/).
- # 9
