Hello, I ask for help to solve a problem. On a clean installation of Novah I installed the Chronoforms v6 component and there is the problem of the disappearance of the dropdowns that you can observe on the site. I state that this only happens on the user side because the preview on the administrator side works correctly. How to solve the problem? Thanks for your help.
Strangely the CSS that is hiding appears from the extension. Just to confirm that this is a template related issue, could you try enabling one of the default Joomla templates (Protostar) and see if the issue still exists?
Hello. I tried to enable both predefined Joomla models (Beez3 and Protostar) and as you can find on the site the problem does not persist. Thanks for your prompt reply
