1. g.signorino
  3. Saturday, 25 April 2020
Hello, I ask for help to solve a problem. On a clean installation of Novah I installed the Chronoforms v6 component and there is the problem of the disappearance of the dropdowns that you can observe on the site. I state that this only happens on the user side because the preview on the administrator side works correctly. How to solve the problem? Thanks for your help.
  1. http://johannan.altervista.org/index.php/prova
Perfect! thanks, everything works now.
Strangely the CSS that is hiding appears from the extension. Just to confirm that this is a template related issue, could you try enabling one of the default Joomla templates (Protostar) and see if the issue still exists?
Hello. I tried to enable both predefined Joomla models (Beez3 and Protostar) and as you can find on the site the problem does not persist. Thanks for your prompt reply
Thank you for checking.
Hello.
As you requested, I sent the information (to info@joomla51.com) to allow administrative access to the Joomla installation.
This issue should be now resolved. Appears to have been related to a CSS class conflict with animate.css
This issue should be now solved on your Joomla installation?
Can this problem be solved? Is there anything I need to do?
As you can see on the site, unfortunately the problem is not solved!
Could you try doing a full refresh on your browser (CTRL + F5). We can no longer replicate this issue.
