1. Anoardo
  3. Thursday, 07 March 2019
Classic Template submenu voice doesn't appear on a Mobile
Phone.... I can see only top level on my website http://www.jacoporanch.it. It works on a PC but not on a mobile phone..... (chrome, firefox, etc). Please Help!
Turns out the solution was a little simpler. We have converted the blank URL menu items to separators and all appears to be now working correctly.
Ok! I sent you an email from [email protected]
thank you!
I notice you have some console errors which appear to be caused by an installed plugin. Trying to find the culprit however you have a large number of plugins installed (200+). Could you try uninstalling any plugins you are not using and I will then take a second look.
....ok I removed all unused plugins.... most was from Hikashop......
Thankyou Ciaran!!! so is not correct to use blank URL menu items as an 'empty' menu' voice? :o
True. Where possible it is always best to use separators.
