1. MySigma
  4. Monday, 07 November 2022
I've added some font styles into the Slide Title of the "J51_LayerSlideshow" module.
<font color="#950e1f">e</font>+<font color="#950e1f">s</font> <font size="+2">GmbH</font> – Expert:innen für Gebäude- und Anlagentechnik</br>
In some browser I'm getting fragments of the Slide Title below the module. I've attached a picture with the issue. I'm quite sure this is just a litte error on my site.
Thank you and kind regards,
Manfred
Hi Manfred
As the title was also used within some alt tags, the html was having some negative effects on your slideshow markup.
Thank you so much. What did you change? Is there now something to take care of with the template?
Regards,
Manfred
Thank you Manfred
Your slide title should now be displaying correctly.
sorry, your code didn't fix it. It seems that the complete code is also inserted as "alt=" attribute of the slideshow picture. Maybe that's the problem for some browsers(versions)?
Regards,
Manfred
As mentioned, the font html tag is not supported in all browsers. Instead, try using the following instead...
<span style="color: #950e1f">e</span>+<span style="color: #950e1f">s</span> <span style="font-size: 2rem">GmbH</span> – Expert:innen für Gebäude- und Anlagentechnik</br>
I've sent you an email. ;-)
Regards,
Manfred
Hi Manfred
Note that the use of font HTML tags is a bit dated and no longer supported in HTML5 (https://www.w3schools.com/tags/tag_font.asp).
Hi!
I've tried it... the " are added automatically again.
Regards,
Manfred
Hello Manfred,
yes they are but they are not mandatory.
You can also write it like this
<font color=#950e1f>e</font>+<font color=#950e1f>
Just try it ;)
Oliver
Hi Oliver,
Which inverted commas do you mean? Do you mean <..="xxx">? They are part of the syntax, aren't they?
Regards,
Manfred
Hallo MySigma,
I think this issue occurs because of the inverted commas ".
If you remove them then it should be solved. I am not quite sure if this was the problem, but I seem to remember that I already had this problem too :D
Oliver
