Revolve template - Homepage LOGO image
I'm not able to change the logo image - only in Homepage
after added some extra menu's
http://www.visiteurope.no
- What can be wrong ?
- vindheim
- Sunday, 04 December 2016
I suspect that you have a number of template styles, only one of which is assigned to your homepage. For further details on this issue may I suggest the following article... https://joomla51.com/tutorials/item/template-options-not-effecting-frontend
Sorry.
This is not my problem. The menu is assigned correct.
It looks like something is set to read only ?
Most links on your site appear to be linking to a different folder (l22no) and not your current Joomla installation. The couple footer menu items linking to your current folder appear to be displaying your set logo (http://farsund2000.com/ww2/index.php/quam-nunc-putamus).
Now I have tried almost "everything" and there must be max number of menu's in this template ?
Change of main site logo:
Extra menu point:
Message
The most recent request was denied because it contained an invalid security token. Please refresh the page and try again.
Delete one menu and change logo:
Message
1 menu item has been assigned or unassigned to this style.
Style successfully saved.
Extra menu point:
Message
Message
There is no limit to the number of menus items you can place in a menu in Joomla. For details on invalid tokens may I suggest the following URL.. https://www.ostraining.com/blog/joomla/invalid-token/ This does not appear to be a template related issue.
Thanks - but
If you login to the site from this post
- Template / Homepage Change the logo – works perfect
- Go the the Menu / Main Menu and add any kind of menu point
- Back to the same template and try to change the Logo, not able to change
- remove the just added menu point
- Now you can change logo again
This problem happen only to Main Menu.
THE MAX NUMBER OF MENU POINT IS 852
853+ and I'm not able to change the Logo
Now I have tested with another free template, and I don't have this problem.
- # 9
Have you sent details of temporary admin access as suggested so we can examine this issue?
- # 11
For future emails please include a URL to the related forum post for our own reference.
Could I ask you to delete any template styles that are not been used which will make this issue easier to troubleshoot considering the number of menu items you have.
- # 13
We are no longer able to access your Joomla administration...
Authorization Required Ciarán
- # 14
We are now able to access your administration. The issue appears to be cache related. Once we clear the cache (System -> Clear Cache) after changing the logo, the new logo appears.
- # 16
Not working.
I added 3 more menu's ( Vindheim.xx x3 ) and are now not able to change logo
Martin
Not working.
Martin
- # 18
Hi Martin
Strange. It is highly unlikely that the menu has any effect on your logo as they are completely unrelated. Have you once again cleared your Joomla cache after changing the logo?
- # 19
Yes cache is cleared,
The problem is still:
- Try with the "Vindheim,xx" menu points
- Delete the 3 last and try.
Size of the menu in database ?
852=0000001101010100 = OK to change logo
853=0000001101010101 = Can NOT change logo
- # 20
- 2
