1. sjudelson
  4. Wednesday, 02 August 2017
Hi Ciarán,
I am using your J51_Vitality template on my site. How can I eliminate or change the color of the thick grey border that appears on the left and right sides of each page? Thanks!
Steven
  1. http://www.new.amagansettseasalt.com
To edit you can add the following to the Custom CSS field of your templates parameters (edit to taste)...
#container_slideshow,
#container_top1_modules,
#container_top2_modules,
#container_top3_modules, #container_main,
#container_bottom1_modules,
#container_bottom2_modules, #container_base,
#container_copyright,
#container_footermenu {
border-color: transparent;
Nice site btw! :)
Fantastic! Thanks for the complement. Even more thanks for your prompt and complete solution. You're the best!:D
I have a related question, Ciarán. I was unhappy with the social media icons at the top of the page on mobile devices, so I placed a social media icon module in the bottom 1-f position of my Vitality template. I added "hidden-desktop" as a Module Class Suffix so that the module would only appear in mobile devices. The module, however, has a grey background (see attached image), which I would like to eliminate. Is this possible?
Sure. To amend try adding the following to the Custom CSS field of your templates parameters..
[class^="social-"], [class*=" social-"] {
Thanks! That did the trick.
One unintended consequence seems to be that the copyright is no longer visible. I suspect the copyright line is still there, but that the color of the font has to be changed (to the blue #2148bd if possible) to be visible. How can I fix this? Thanks in advance.
Steven
Never mind my latest post, Ciarán. I solved my invisible copyright color problem by addiing the below to the Custom CSS section. Sorry for not searching the forum before posting.
#copyright {
color: #000;
