Hi Ciarán,
I am using your J51_Vitality template on my site. How can I eliminate or change the color of the thick grey border that appears on the left and right sides of each page? Thanks!
Steven
- sjudelson
- Wednesday, 02 August 2017
Fantastic! Thanks for the complement. Even more thanks for your prompt and complete solution. You're the best!
Sure. To amend try adding the following to the Custom CSS field of your templates parameters..
[class^="social-"], [class*=" social-"] {
} Ciarán
Never mind my latest post, Ciarán. I solved my invisible copyright color problem by addiing the below to the Custom CSS section. Sorry for not searching the forum before posting.
#copyright {
color: #000;
#copyright {
color: #000;
To edit you can add the following to the Custom CSS field of your templates parameters (edit to taste)...
#container_slideshow,
#container_top1_modules,
#container_top2_modules,
#container_top3_modules, #container_main,
#container_bottom1_modules,
#container_bottom2_modules, #container_base,
#container_copyright,
#container_footermenu {
border-color: transparent;
} Ciarán
I have a related question, Ciarán. I was unhappy with the social media icons at the top of the page on mobile devices, so I placed a social media icon module in the bottom 1-f position of my Vitality template. I added "hidden-desktop" as a Module Class Suffix so that the module would only appear in mobile devices. The module, however, has a grey background (see attached image), which I would like to eliminate. Is this possible?
Thanks! That did the trick.
One unintended consequence seems to be that the copyright is no longer visible. I suspect the copyright line is still there, but that the color of the font has to be changed (to the blue #2148bd if possible) to be visible. How can I fix this? Thanks in advance.
Steven
Steven
