1. wallis
  4. Saturday, 12 March 2016
Hi Ciarán
I need to lighten the sub-menus background on Boss template. I’ve tried several approaches taken from previous questions in the forum but none worked. I had a look to ‘nexus.css’ file but I don’t recognize the line to be altered, and assuming it is the correct file. May I have your help again?
Thank you for your precious patience.
Wallis
In the meantime I found the answer. I’ve edited the background color via the 'Menus' tab of the templates parameters. But I still need help to implement some transparency, if possible.
wallis
Hi Wallis
Thank you for the update.
#hornav ul ul {
background-color: rgba(255, 255, 255, 0.8);
Thank you, Ciarán
I appreciate very much your help.
wallis
