1. Deikvan
  3. Wednesday, 26 October 2016
Hi all,
i bougt the template Caitlin and trying to set it up right now.
I put my main menu in the hornav but it stays on the left side. i want to center it. any ideas?
the other question ist how i can put in the login form horizontal in the hornav.
those are problably newbi question but i m new in this business :-)
would be great if you can help me
Deikvan
http://j3.online-racing-club.de/
To center your menu try adding the following to the Custom CSS field of your templates parameters...
.hornav > ul {
text-align: center;
If you firstly place your login module in the header-2 module position we can then put together the CSS needed to get it horizontal.
That worked! Thanks a lot :-)
I put the login module in header 2
Thank you however it appears you have decided to place your login module in the sidecol-b module position instead. Is this correct?
Good morning,
i still want to place the login in the hornav. I just tested around because you where not online anymore.
I put it back and leave it there now.
thanks for your help.
Deikvan
I just looked around in the forum an found some intresting blogs.
https://www.joomla51.com/tutorials/item/adding-a-module-to-the-menu-dropdown
(if i could implement it like this, ist would be great, but it doesn t seem to work on the Caitlin template)
A login like in the demo http://www.joomla51.com/demo/0133/ would be ok for me too but if i put it in header 1, the hornav gets way to big.
thanks
Deikvan
Hi Deikvan
Admittedly the area you have available would be to small to accommodate a login form. To create a login button similar to that of our 'Caitlin' template following the following steps..
1. Create a new menu called 'Login Menu'.
2. Within this menu create a menu item linking to your login (Menu Item Type -> Users -> Login Form)/
3. Create a menu module for this menu item in the header-2 module position (Styling can bu supplied if needed).
thanks, i tryed that and it somehow it worked i think. but thats not how i wanted it. it doesnt shows that you are online after you are logged in.
I got to look for something else. Can i somehow put it over the header backround images? in the right upper corner?
If not i ll probably just put it in the sidecontrol.
Can you tell me how i center the side control? i tryed it withe the css. comand you gave me for the hornav (just put in sidecontrol instead, but it didn t word.
It may be worth considering a login module extension. There is a number of options available which will offer you a more compact version of the login module...
https://extensions.joomla.org/extension/loginplus
https://extensions.joomla.org/extension/bt-login
https://extensions.joomla.org/extension/login-styles
https://extensions.joomla.org/extension/sclogin-enhanced-login
