1. Mol4
  4. Tuesday, 23 February 2016
is it possible to use buttons instead of Prev and Next for the Carousel extension?
I tried to use < and > but somehow this isn\'t possible.
Thanks!
Would you have a URL to an example of your carousel module?
Hello Ciarán,
this is the URL
Thanks!
In your carousel modules default.php (../modules/mod_j51carousel/tmpl/default.php) try replacing the following (line 121)...
navigationText: ["<?php echo $j51_text_prev ?>","<?php echo $j51_text_next ?>"],
With...
navigationText: ["<",">"],
You can also experiment with this with some Font Awesome icons etc. Note for this module we used the Owl Carousel script which comes with a host of other options which can be added to the same area (http://owlgraphic.com/owlcarousel/).
Hello Ciarán,
thanks! This did the trick.
Greetings,
Ton
Excellent... thank you for the update!
So how would you use Font Awesome arrows instead of text for navigation?
Thanks.
Sorry to say there is no current option to replace the navigation text with FontAwesome icons.
Thanks anyways.
