1. sdoratti
  3. Thursday, 15 January 2026
I just installed the latest Colette template on a brand new installation of a Joomla 5.4.2 website. When I go to adjust the body/header/gradient colours to be the same as my last website, I can't access that tab (see screenshot attached). I can change module/components on down, but not the body/header/gradient.
I am also not able to display the top menu on the hornav position.
Can you be of assistance?
  1. http://desertdesigns.ca/
I got the top menu figured but still am at a loss to figure out how to get the template body/header/gradient part of the tab to work or be visible.
Good morning,
did you clear the cache after installation?
A customer had a similar problem after a fresh installation; after clearing the cache, the template settings were displayed correctly.
Best regards
I just cleared the cache and it looks the same. Thanks for the suggestion! Hopefully I can get it sorted out, it looks much better with the example 4 palette.
This similar topic was also discussed here:
https://www.joomla51.com/forum/template-amelia-doesn-t-work-at-joomla-5
Perhaps ask the original poster in this thread. I think it was due to the cache.
Best regards
I have replied to the thread, but so far no response. What does anyone think about me loading the preset style 4 from the demo installer? I woke up with the thought of doing a module style override but with the positions of body, header and gradient colors not being modules, that won't work.
Any help appreciated, many thanks
Hello.
For me, the problem occurred when I installed the new version directly over the old one. That's when these complications arose. I had to completely uninstall the old template version and only then install the new one. After that, I had to clear the cache. That worked perfectly for me.
