1. sdoratti
  3. Thursday, 15 January 2026
I just installed the latest Colette template on a brand new installation of a Joomla 5.4.2 website. When I go to adjust the body/header/gradient colours to be the same as my last website, I can't access that tab (see screenshot attached). I can change module/components on down, but not the body/header/gradient.
I am also not able to display the top menu on the hornav position.
Can you be of assistance?
  1. http://desertdesigns.ca/
Good morning,
did you clear the cache after installation?
A customer had a similar problem after a fresh installation; after clearing the cache, the template settings were displayed correctly.
Best regards
Hello.
For me, the problem occurred when I installed the new version directly over the old one. That's when these complications arose. I had to completely uninstall the old template version and only then install the new one. After that, I had to clear the cache. That worked perfectly for me.
I got the top menu figured but still am at a loss to figure out how to get the template body/header/gradient part of the tab to work or be visible.
I just cleared the cache and it looks the same. Thanks for the suggestion! Hopefully I can get it sorted out, it looks much better with the example 4 palette.
This similar topic was also discussed here:
https://www.joomla51.com/forum/template-amelia-doesn-t-work-at-joomla-5
Perhaps ask the original poster in this thread. I think it was due to the cache.
Best regards
I have replied to the thread, but so far no response. What does anyone think about me loading the preset style 4 from the demo installer? I woke up with the thought of doing a module style override but with the positions of body, header and gradient colors not being modules, that won't work.
Any help appreciated, many thanks
