1. MBCarter
  3. Wednesday, 18 June 2014
my awesome fonts are not working ,, with my other website it worked fin e but on this one is doesn't work,
http://www.stenenbaas.nl
i tried it at the menu manager and then by Link CSS Style: fa-phone
it doenst work :9 please help
Solved,
I wrote l-ink instead of link, damn :blush: :blush:
It seems to work now. Thanks
I'm sorry but it doesn't works. I have tried to add both to header and body.
As soon as I activate CDNforJoomla and empty cache the icons are not shown.
Thanks for any help
Yes.. adding the above CDN code to your Custom Code field should resolve any issues of the icons not appearing on our Habitat template.
I'm having a very similar issue now but it appeared just after trying to use a CDN for our site with the Joomla plugin "cndforjoomla"; the awesome icons are not showing.
I'm using template Habitat
Should I add the mentioned code to my template ?
Thanks ;)
thanks a lot, and thanks for the fast response.. :)
We have amended this issue by loading Font Awesome via a CDN by adding the following to the Custom Code field of your templates parameters..
<l-ink href="//http://maxcdn.bootstrapcdn.com/font-awesome/4.1.0/css/font-awesome.min.css" rel="stylesheet">
Note: Replace 'l-ink' with 'link'
