1. MBCarter
  3. Wednesday, 18 June 2014
my awesome fonts are not working ,, with my other website it worked fin e but on this one is doesn't work,
http://www.stenenbaas.nl
i tried it at the menu manager and then by Link CSS Style: fa-phone
it doenst work :9 please help
We have amended this issue by loading Font Awesome via a CDN by adding the following to the Custom Code field of your templates parameters..
<l-ink href="//http://maxcdn.bootstrapcdn.com/font-awesome/4.1.0/css/font-awesome.min.css" rel="stylesheet">
Note: Replace 'l-ink' with 'link'
thanks a lot, and thanks for the fast response.. :)
I'm having a very similar issue now but it appeared just after trying to use a CDN for our site with the Joomla plugin "cndforjoomla"; the awesome icons are not showing.
I'm using template Habitat
Should I add the mentioned code to my template ?
Thanks ;)
Yes.. adding the above CDN code to your Custom Code field should resolve any issues of the icons not appearing on our Habitat template.
I'm sorry but it doesn't works. I have tried to add both to header and body.
As soon as I activate CDNforJoomla and empty cache the icons are not shown.
Thanks for any help
Solved,
I wrote l-ink instead of link, damn :blush: :blush:
It seems to work now. Thanks
