Ciaran,
Using j51-Ensley demo files.
Added the following fonts to templates/j51_ensley/fonts
AvenirLTStd-Book.woff
AvenirLTStd-Book.woff2
AvenirLTStd-Medium.woff
AvenirLTStd-Medium.woff2
AvenirLTStd-Roman.woff
AvenirLTStd-Roman.woff2
Added the following text to templates/j51_ensley/css/custom.css
@font-face {
font-family: 'Avenir LT Std';
src: url('../fonts/AvenirLTStd-Medium.woff2') format('woff2');
src: url('../fonts/AvenirLTStd-Medium.woff') format('woff');
font-weight: 500;
font-style: normal;
@font-face {
src: url('../fonts/AvenirLTStd-Roman.woff2') format('woff2');
src: url('../fonts/AvenirLTStd-Roman.woff') format('woff');
font-weight: normal;
font-style: normal;
@font-face {
src: url('../fonts/AvenirLTStd-Book.woff2') format('woff2');
src: url('../fonts/AvenirLTStd-Book.woff') format('woff');
font-style: normal;
Enabled custom.css in Templates: Edit Style/Custom CSS/Load http://custom.css/YES
Added woff2 to “Valid Font Formats” (woff2,woff,ttf,otf)
In Templates: Edit Style/General/Logo/Logo Font couldn’t find new Avenir fonts.
What have I left out?
Thanks,
Keith
- keithvb
- Saturday, 20 March 2021
Hi Peter
I have just checked your font URLs and they appear to be giving me a 404 error for each font (eg. https://oasttheatre.com/public_html/templates/j51_chloe/fonts/avenirltstd-book-webfont.woff). Maybe it should be https://oasttheatre.com/templates/j51_chloe/fonts/avenirltstd-book-webfont.woff instead?
I have amended the custon.css file as directed, and set load custom.css to Yes, refreshed the browser, but still do no see the fonts. Would you kindly take a look please?
Hi Peter
The custom.css file can be added to your templates CSS folder. Once added you can enable its use via the Custom CSS tab within your template style settings.
I am trying to add the same Avenir font to Chloe. I don't see the same custom.css as described by Keith. Can you help me with instructions to load Avenir Next Condensed.ttc, Avenir Next.ttc, and Avenir.ttc please?
Many thanks
Peter
Many thanks
Peter
Great... thank you for the update.
A quick tip on refreshing your browser with a clean cache is to use CTRL + F5.
I've solved 2 of my problems.
1. Thanks Ciaran for the flexbox tip. After digging into flexbox (new to me) I learned enough to work with it.
2. The reason I couldn't see the custom.css rules was due to the browser cache not flushing. I discovered this by removing custom.css which had no effect on my preview until I cleared the cache.
Thanks for all your help.
Keith
Keith
Thanks for your help. i suspect I've done something strange...
Nothing is working as I think it should.
I'm starting over.
I'm starting over.
Hi Keith
Your custom.css appears to be loading without any issue. For your CSS rule try the following instead as 'align-items: left;' is not valid....
.layerslideshow .item-align-center .info {
align-items: flex-start;
- # 9
Thanks. I tried it and no change.
I have discovered that custom.css isn't loading.
In attempting to move the info box on the home page to the left I added
align-items: left !important;
to custom.css and custom.css doesn't appear in the inspector (see attached image)
so I suspect I missed something.
Keith
Keith
- # 10
Hi Keith
Your font file doesn't not appear to be loaded which would indicate an incorrect path. Try replacing all paths with a full URL...
@font-face {
src: url('http://www.artgallery.keithvb.com/templates/j51_ensley/fonts/AvenirLTStd-Roman.woff2') format('woff2');
src: url('http://www.artgallery.keithvb.com/templates/j51_ensley/fonts/AvenirLTStd-Roman.woff') format('woff');
font-style: normal;
- # 11
Hi Keith
Please include a URL to your site and I will examine these issues further.
- # 13
I'd like to add that custom.css is not being accessed for other changes I want to make.
It works for me in other templates but for some reason not in Ensley...
Added this to reposition the info box
/* move info box */
.layerslideshow .info {
top: 200;
left: 0;
right: 0;
bottom: 0;
Noticed that the new fonts appear correctly in "Templates customize: j5-Ensley" / fonts
/* move info box */
top: 200;
left: 0;
right: 0;
bottom: 0;
- # 14
