Ciaran,
Using j51-Ensley demo files.
Added the following fonts to templates/j51_ensley/fonts
AvenirLTStd-Book.woff
AvenirLTStd-Book.woff2
AvenirLTStd-Medium.woff
AvenirLTStd-Medium.woff2
AvenirLTStd-Roman.woff
AvenirLTStd-Roman.woff2
Added the following text to templates/j51_ensley/css/custom.css
@font-face {
font-family: 'Avenir LT Std';
src: url('../fonts/AvenirLTStd-Medium.woff2') format('woff2');
src: url('../fonts/AvenirLTStd-Medium.woff') format('woff');
font-weight: 500;
font-style: normal;
@font-face {
src: url('../fonts/AvenirLTStd-Roman.woff2') format('woff2');
src: url('../fonts/AvenirLTStd-Roman.woff') format('woff');
font-weight: normal;
font-style: normal;
@font-face {
src: url('../fonts/AvenirLTStd-Book.woff2') format('woff2');
src: url('../fonts/AvenirLTStd-Book.woff') format('woff');
font-style: normal;
Enabled custom.css in Templates: Edit Style/Custom CSS/Load http://custom.css/YES
Added woff2 to “Valid Font Formats” (woff2,woff,ttf,otf)
In Templates: Edit Style/General/Logo/Logo Font couldn’t find new Avenir fonts.
What have I left out?
Thanks,
Keith
- keithvb
- Saturday, 20 March 2021
I'd like to add that custom.css is not being accessed for other changes I want to make.
It works for me in other templates but for some reason not in Ensley...
Added this to reposition the info box
/* move info box */
.layerslideshow .item-align-center .info {
align-items: left !important;
.layerslideshow .info {
top: 200;
left: 0;
right: 0;
bottom: 0;
Noticed that the new fonts appear correctly in "Templates customize: j5-Ensley" / fonts
/* move info box */
top: 200;
left: 0;
right: 0;
bottom: 0;
Hi Keith
Please include a URL to your site and I will examine these issues further.
Hi Keith
Your font file doesn't not appear to be loaded which would indicate an incorrect path. Try replacing all paths with a full URL...
@font-face {
src: url('http://www.artgallery.keithvb.com/templates/j51_ensley/fonts/AvenirLTStd-Roman.woff2') format('woff2');
src: url('http://www.artgallery.keithvb.com/templates/j51_ensley/fonts/AvenirLTStd-Roman.woff') format('woff');
font-style: normal;
}Ciaran
Thanks. I tried it and no change.
I have discovered that custom.css isn't loading.
In attempting to move the info box on the home page to the left I added
to custom.css and custom.css doesn't appear in the inspector (see attached image)
so I suspect I missed something.
Keith
Keith
Hi Keith
Your custom.css appears to be loading without any issue. For your CSS rule try the following instead as 'align-items: left;' is not valid....
align-items: flex-start;
}Ciaran
Thanks for your help. i suspect I've done something strange...
Nothing is working as I think it should.
I'm starting over.
I'm starting over.
I've solved 2 of my problems.
1. Thanks Ciaran for the flexbox tip. After digging into flexbox (new to me) I learned enough to work with it.
2. The reason I couldn't see the custom.css rules was due to the browser cache not flushing. I discovered this by removing custom.css which had no effect on my preview until I cleared the cache.
Thanks for all your help.
Keith
Keith
Great... thank you for the update.
A quick tip on refreshing your browser with a clean cache is to use CTRL + F5.
- # 9
I am trying to add the same Avenir font to Chloe. I don't see the same custom.css as described by Keith. Can you help me with instructions to load Avenir Next Condensed.ttc, Avenir Next.ttc, and Avenir.ttc please?
Many thanks
Peter
Many thanks
Peter
- # 10
Hi Peter
The custom.css file can be added to your templates CSS folder. Once added you can enable its use via the Custom CSS tab within your template style settings.
- # 11
I have amended the custon.css file as directed, and set load custom.css to Yes, refreshed the browser, but still do no see the fonts. Would you kindly take a look please?
- # 12
Hi Peter
I have just checked your font URLs and they appear to be giving me a 404 error for each font (eg. https://oasttheatre.com/public_html/templates/j51_chloe/fonts/avenirltstd-book-webfont.woff). Maybe it should be https://oasttheatre.com/templates/j51_chloe/fonts/avenirltstd-book-webfont.woff instead?
- # 14
