Is there a way to define the basic backgrounf color of the hornav menu? I have found the "Menu Item Hover Color", but i would like also to change the "Menu Item Color"
Presuming I understand you correctly, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
