1. AStrasser
  3. Friday, 20 April 2018
Is there a way to define the basic backgrounf color of the hornav menu? I have found the "Menu Item Hover Color", but i would like also to change the "Menu Item Color"
Best regards
Axel
Presuming I understand you correctly, try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS)...
Edit to taste..
.hornav .menu {
background-color: #cb9a95;
I found something, but it works not really the way I want.
.hornav > ul > li > a {
font-size: 18px;
padding: 8px 10px;
text-transform: none;
I would like to have the same behaviour like the small menu (see picture
Axel
