1. DiabloV
  4. Friday, 25 July 2014
Hello there.
Template CLARITY
http://sge-eschau.fr/index.php/contact
I have an article done with JCE latest version fr. jommla 3.3.2
when I add a mailto link, it creates me a jump to the line only visible in frontend.
Marylène
: 03 88 64 12 25
Céline : 06 61 87 14 09
same for the other links
it's the same thing with tinymce.
What is this strange phenomenon?
with the internal link, there's not that jump.
Great!!.. thank you for the update :)
after an update to 3.3.3, the problem is solved itself !
lol ! magic !
thanks
Not sure if I understand you correctly. Your mailto links appear to working as they should? What do you mean by 'jump to the line'?
