1. DiabloV
  4. Friday, 25 July 2014
Hello there.
Template CLARITY
http://sge-eschau.fr/index.php/contact
I have an article done with JCE latest version fr. jommla 3.3.2
when I add a mailto link, it creates me a jump to the line only visible in frontend.
Marylène
: 03 88 64 12 25
Céline : 06 61 87 14 09
same for the other links
it's the same thing with tinymce.
What is this strange phenomenon?
with the internal link, there's not that jump.
Not sure if I understand you correctly. Your mailto links appear to working as they should? What do you mean by 'jump to the line'?
after an update to 3.3.3, the problem is solved itself !
lol ! magic !
thanks
Great!!.. thank you for the update :)
