1. pedra
  4. Tuesday, 04 September 2018
Hello Ciaràn,
I want to use the Amelia template.
How can I insert a background image in the template Amelia and make the sidebar with the main navigation transparent?
Thanks!
Replace the # with a URL to your image.
#body_panel {
background-image: url('#');
background-size: cover;
background-attachment: fixed;
#container_header {
Sounds easy.
Incidentally, Magnolia is also a wonderful template.
Thank you for the fast answer.
Thank you, that worked well.
Maybe you have a hint to hide the backgroundimage on the mobile device view.
One option is to wrap the suggested CSS in a media query (edit to taste)...
@media only screen and (min-width: 960px) {
#body_panel {
#container_header {
A very good hint. Instead of removing the background image, I replaced it. And everything worked perfectly. Thanks for the good service
