Bonjour,
Le module J51_News ne s'affiche pas sue les navigateurs Edge et Chrome.
J'ai désactivé custom.css car il y avait pas mal de modifications ainsi que JCH Optimize mais çà ne change rien.
Avez-vous une idée du problème ?
Version : 3.10.11
Merci pour votre aide
The J51_News module is not displayed on Edge and Chrome browsers.
I disabled custom.css because there were a lot of modifications as well as JCH Optimize but that doesn't change anything.
Do you have an idea of the problem ?
Version: 3.10.11
Thanks for your help
Would you have a URL directly to an example of your News module? I dont see an example on your homepage (https://www.rko.fr/).
The module is visible on the home page of http://www.rko.fr with only the firefox browser not with Edge and Chrome
Christian
Christian
In fact, when I go to another page and come back to the home page, the module no longer appears (see attached image)
I refreshed the browser, cleared the cache, erased the navigation data!
Christian
Christian
.j51news_inside.owl-carousel {
display: block;
}Ciaran
Unfortunately that doesn't work! see attached picture)
Christian
Christian
Maybe I miss understand your query. Is the news module not been displayed in your screenshot (below the black bar)?
We see on the image the module which is displayed under the black bar.
Only 2 news items are displayed and they are fixed.
Christian
Christian
- # 9
Hi Christian
As a reference, we are using Firefox and we are finding that both Chrome and Firefox are displaying your site the same. Is there a particular platform where your site is displaying correctly?
- # 10
On Firefox, the display is normal.
On Chrome, after emptying the site and browser cache and deleting the browsing history, the J51_news module is displayed but if you browse to another page on the site and return to the home page, the J51_news module is no longer displayed.
On Edge, after emptying the site and browser cache and deleting the browsing history, the J51_news module is displayed but if you navigate to another page on the site and return to the home page, the J51_news module is no longer displayed.
On Firefox, Edge and Chrome, the tests were done without the code that you suggested I put in the custom.css file
With the code in custom.css:
On Firefox, no problem (view firefox picture)
On Chrome, after emptying the site and browser cache and deleting the browsing history, the J51_news module does not display normally, there are only 2 news displayed instead of 3 and the scrolling does not work.(view chrome picture)
On Edge, after emptying the site and browser cache and deleting the browsing history, the J51_news module is displayed but if you navigate to another page on the site and return to the home page, the J51_news module is not displayed normally, only 2 news items are displayed instead of 3 and scrolling does not work.
(view edge picture)
Christian
(view edge picture)
Christian
Attachments (3)
- # 11
Hi Christian
- # 12
Good evening,
I sent you an email with the identifiers to the rko.fr site and the link to this post.
Christian
Christian
- # 13
Thank you Christian
I have reinstalled your template and module and all appear to be now displaying correctly.
- # 14
Can you remove the white band that I didn't have before your intervention?
Attached are screenshots
thanks in advance
Christian
thanks in advance
Christian
- # 15
