1. fap
  3. Sunday, 29 October 2023
how can i display the current year in the footer-copyright "update-safe" and without a thirt-party extension?
Thank you!
fap
go to template style | General | | copyright and edit the year
@FrancW: Thank you for your Answer!
This Field is empty for me.
what I have to enter there for the current year?
fap
what year is it?
just fill it in.
To add the current year dynamically you can use the following in the copyright field..
<span><script>document.write( new Date().getFullYear() );</script></span>
Hello @ciaran: That's what i mean.
Thank you!
Best Regards
fap
what about prefilling this little script into the copyright field of your templates (as a little service ;) )?
Rolf
I used to have a template where you would replace the current year with a "hook" like '(c)' and it would automatically replace that with the current year. So, for exmple, you could have
'Copyright: Bears Photography 2003-(c) all rights reserved'
and it would display
'Copyright: Bears Photography 2003-2023 all rights reserved'
all by itself. Was a wonderful feature.
Thank you for the suggestion. Based on this, we are currently looking into the possibility of creating a shortcodes plugin for Joomla which render such content based on bracketed text (eg. [currentYear]). I will keep you posted :)
