1. dinkster07
  3. Monday, 23 December 2019
J51 Madison template in Joomla. Just upgraded to the latest stable version of Joomla...3.9.14. Now when super users are logged into my frontend, they can't access my Zap Calendar menu items. They get a page that says "500 - JHtmlIcon::edit not found." Joomla forums suggest deleting a /html/com_content folder in my template tree due to maybe some conflicting override, but that doesn't exist. I don't suppose you'd know where to start looking to resolve this problem? Thanks.
So, if you go to view my post at the Joomla forum, here, you'll see that I went into more depth about my problem. It would seem the issue is in the template. I'm using J51_Madison. I absolutely love the template and its rich features, including from the administrator site. I don't want to stop using it. Is there any way you can solve this issue for me? Thanks.
A couple of quick tests you can do. Firstly rename the folder ../templates/j51_madison/html to html-backup and see if the issue persists. If the issue is no longer present then you can assume that it is a template override issue. Also, try disabling all other modules. This just confirms that the issue is template related.
../templates/j51_madison/htmlb] to [b]html-backup
I'm assuming you just mean /templates/j51_madison/html and that the "b's" in your reply are a typo?
First, I changed the name to html-backup and cleared my site's cache. The issue still existed when logged in as a super user.
Then I remembered that whenever I was logged in as a super user, a module using your J51ThumbsGallery module was appearing out of sorts. It's in position base-1b. Reason being, I had implemented the "Articles Anywhere" plugin in the module title in the backend, so that I could use an article in place of the normal title to fancy it up with an icon next to the title. It worked, so I left it that way. After your comment above, I disabled the module and my Zap Calendar issue went away. So, I replaced the articles anywhere reference with a normal module title. Tada! Thanks for your insight!
Keep up the great work! A very nice template.
Excellent.. thank you for the update and for sharing your solution.
Happy new year! :)
