Hi there (again
) I purchased and downloaded the new file, then installed the Joomla 3 template. However, the new install appears to have overwritten the changes. None of the customizations are showing at all
Just to clarify. I have two Oxygen based templates:
The first is the main site template and the changes have been made on the actual J51_oxygen template (I have saved the original file on my laptop so it's intact)
The other is a template for use on certain pages only. I copied the original file and renamed it and made the changes on the new file
I'd be grateful if you can tell me what I have done wrong here? Did I miss something in your earlier instructions?
Thanks so much.
Jude
