1. chrishoefliger
  4. Sunday, 11 September 2022
Hi Ciarán,
no, this is not about the issue with Skylar as reported last week (even though Nina suffers from the same problem).
It's like this: I have an elderly site that I am about to lift to Joomla 4. This site has been running Sophia and I did not want to buy an upgrade as I hardly used this template in the past. Besides, said site runs K2 and I want to get rid of this, so I thought the main problem would be to get rid of all K2 items (wich turned out not to be that complicated, as I found a script to do the main task).
Then I installed Nina 1.1.7 (current version as far as I can see). Looking at the network tab, I noticed that there are a few new 404 errors. Seems the template is looking at the wrong places to load Font Awesome:
/media/templates/site/j51_nina/css/webfonts/fa-solid-900.woff2
There isn't any such folder in the system.
After a while I tried to install an older version of Nina that I had downloaded earlier: V 1.1.2 - and snap the problem disappeared.
/media/templates/site/j51_nina/fonts/fa-solid-900.woff2
So, somebody must have decided at one point to change the location and the name of Font Awesome and not telling the template logic.
I have re-installed 1.1.7 and then copied and renamed the fonts directory. This has proved to be a temporary fix, but I feel this has to be put right in a future version of the template.
Cheers, Chris
Hi Chris
Thank you for detailing your issue. There seem to be some issues related to the introduction of child templates into Joomla. This update has moved some of the template assets from the template folder into the media folder. The migration for this change appears to be having some issues. If this is still an issue for you, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
The new version 1.1.9 of the template seems to solve this issue.
Thanks a lot.
Cheers, Chris
