1. kettumatti
  3. Sunday, 14 January 2024
I just noticed that there are lots of 404 requests to: /media/templates/media/vendor/joomla-custom-elements/css/joomla-alert.css
Correct path is without "/media/templates" in the beginning. 404 error is easy to fix with redirection but it would be better if it's corrected in the templates :)
Affected templates are at least Bianca, Stockholm and Hayley.
Thank you for reporting this issue. I have just created a new update to the Bianca template which I hope will resolve this issue. Could I ask you to re-download your Bianca template and install the latest version of the template. If you could let me know if this update does indeed resolve the issue, I will then create a similar update for the other templates.
Sorry about the delay. It looks like the update fixed the problem.
Thank you! :)
Hi, i have the same error at the Sophia template for joomla V.4 (download at 24 Feb 2024). Can you also fix this template?
We have just updated the Sophia template. Installing this latest update should resolve this issue for you.
I've got this on Novah, Layla, Hayley as well.
