1. webxc-mfx
  3. Friday, 17 March 2017
I'm using the Willow template on one of our websites and when we click the menu items in the top menu the slideshow image appears to be, very briefly, loading all or at least more than one, of the images in the showcase area.....it has a "jumping" appearance....I don't know how else to explain it. We've used this template on other websites and in checking we found it does it on all of them.....some worse than others. In checking the demo we noticed it does the same thing....not always but at least some of the time. The url of one of the websites we're noticing this on is dev.belgradelakesmarine.com. We've checked in using all browsers except Internet Explorer and checked it on a Windows computer and a Mac and it does the same on all of them. Any suggestions for a solution would be appreciated.
Firstly my apologies for the delay in replying to your query. We have spent the last few days at a Joomla 4 code sprint and fell a little behind in our support.
Admittedly this is an issue we are unable to replicate on a number of different devices. Regardless, a bit of a shot in the dark but to amend try adding the following to the Custom CSS field of your templates parameters...
.navslideshow {
height: 520px;
Thank you for the emailed video of your issue. :)
Considering this could you try adding the following CSS to the Custom CSS field of your templates parameters...
.navslideshow, .showcase {
height: 520px;
overflow: hidden;
Bonsoir,
Je suis en train de créer un nouveau site avec le template WILLOW. Sur la home, j'ai installé les 2 modules "mod_j51navslideshow" et "mod_j51caroussel". Quand ils sont sur la même page (mais pas sur la même position), le module "mod_j51navslideshow" ne fonctionne pas. Quand je clique sur les mots les images ne changent pas .
Quand je dépublie le module "mod_j51caroussel", le module "mod_j51navslideshow" fonctionne !
une idée ?
merci
  1. http://moulindecharme-ariege.com/site_v2/index.php
Si pas de solution, y-a-t-il un module "slideshow" normal que je puisse utiliser à la place du "mod_j51navslideshow" ?
merci
Bonjour,
Merci pour votre retour.
Voici l'accès à l'administration du site sous JOOMLA :
ident : REMOVED
mdp : REMOVED
à bientôt
  1. http://moulindecharme-ariege.com/site_v2/administrator/
Thank you for bringing this issue to our attention.
There appears to be a conflicting issue here which we are currently looking to amend. Hopefully we can resolve this issue shortly. In the mean time you can try using an alternative slideshow module for your slideshow...
https://extensions.joomla.org/category/photos-a-images/slideshow/
https://www.joomla51.com/free-module-extensions/item/j51-slideshow
merci Ciaran pour votre recherche de solution, en attendant je vais installer un slideshow classique (https://www.joomla51.com/free-module-extensions/item/j51-slideshow)
Je reste à votre écoute, intéressée par la solution
cdlt
