1. strope
  3. Thursday, 23 June 2016
First of all, I like your template, it's really nice! I'm setting up a website for a local band. I'm new in Joomla. Might be a easy fix for experts... ;)
I have a problem with the main container, when I loaded a modul in the content. The container is now placed at the upper end of the screen and its not possible to scroll down. The content is behind the menu bar. Tried to fix it but without success. Example attached. Somebody any idea?
Second problem I found is in the mobile view. Social icons covering menu. Is it possible to move the icons to the left?
Thanks for your help
Peter
Hi Strope
1. I suspect this may be related to a Javescript conflict on your site. A possible solution would be to install the jQuery Easy plugin. For more details on the subject may I suggest the following article.. http://www.joomla51.com/tutorials/item/resolving-javasript-errors-in-joomla-using-jquery-easy
2. To amend try adding the following to the Custom CSS field of your templates parameters...
#socialmedia {
left: 0;
Hi Ciarán
thanks for the quick reply. Custom CSS worked fine for the social icons!
For the issue with the javascript I have to find an other solution. I installed jQuery easy and run it. But now the music player does not work any more. It's a java based module. The good thing, the main container is back to it's normal position. I don't have the knowlage to modify the java.
Peter
Hi Peter
Thank you Peter
We appear to be having an issue getting your music player to work even with jQuery Easy disabled. I notice the module was not assigned to any menu items and was also set to be published at a future time. Amending these still did not display your player. I am not familiar with the module however it appears to be assigned to a module position that is not on the template. Is this correct?
Hi Ciarán
problem solved (music player)! Disabled jQuery of the player module and removed jQuery-Easy.
Module position is a custom one to display the player in an article => {loadposition positionname}
Thank you for you help so far. I really appreciate.
Peter
Excellent.. thank you for the update and for sharing your solution! :)
