1. THP-Tanja
  3. Friday, 03 February 2017
is there a way to use klixo watermark for K2 and SIG with the thumbsgallery of the chelsea template? Or is there another way to protect images with a watermark?
Thanks for help
Tanja
Hi Tanja
Sorry to say there is no option within our ThumbsGallery module to automatically add watermarks to each image.
Hi Ciarán,
thanks for the quick reply.
The thumbsgallery works with a lightbox, and the Klixo watermark plugin supports this. I have to fill in the class(es) used for the lightbox links. Can you tell me the class(es) the thumbsgallery uses? That would be great!
Thanks a lot
Tanja
Hi Tanja
Presuming you are referring to the CSS class you could try '.full-image img'.
Hi Ciarán,
thanks, but that doesn't work. The other lightboxes classes are e.g. jcepopup, rokbox, artsexylightboxpreview. Any other idea?
Tanja
Hi Tanja
As I am not familiar with the plugin, I would not be in the best position to support it. Have you tried contacting your plugins developers on the issue?
