1. kpomilla
  3. Thursday, 26 January 2017
I'm using Vitality template, and it works well on a PC. Once I go to a mobile device, the screen exhibits some odd behavior. The screen flashes when the header background image changes and it slides to the right instead of remaining "full screen"...
Here's what I'd like to accomplish:
1) Eliminate the header background images on mobile devices
2) On mobile devices, is there any way to put the logo at the same level as the menu button?
3) Eliminate the "sliding" to the right on mobile devices ( I'm pretty sure it's a padding or border issue, but can't seem to fix)
Here is a link to the site (in testing right now): http://thewebstoretest.com/martys
Thanks in advance for all your help.
Ken
  1. http://thewebstoretest.com/martys
Yes, that worked. Thanks so much for your help!
Hi Ken
1. To amend try adding the following to the Custom CSS field of your templates parameters...
.touch #header_bg {
height: 196px !important;
.touch .vegas-slide {
display: none;
2. Sorry to say this option is not available with this template.
3. May I ask on which device are you having this issue?
Ciarán,
Thank you for your response.
Issue #1 resolved with your suggestion.
Issue #3, I'm on a Samsung phone, and in portrait mode, I experience the "sliding" of the screen, but in landscape mode, it seems to work fine.
Does adding the following to the Custom CSS field of your templates parameters help in any way?
@media (max-width: 767px) {
h1 {
font-size: 2em;
