1. Klumpi
  3. Wednesday, 09 December 2015
since today the virus scanner reports the discovery of a Trojan horse in the caption.js when calling my new page. I use the Template Revolve. Even when calling Joomla51.com this message appears. How can I resolve the problem?
Best regards
Sven
sorry, translated by Google ;)
Hi Sven
I am not sure if this is a template related issue as there is no caption.js within the templates JS files. Would you have a URL to an example of this issue?
i know the caption.js part of Joomla. But only when the new page, the problem arises. The original aspect under Joomla 2.5 running smoothly.
The problem side (construction site):
the old page
Hi Sven
Unfortunately we have been unable to replicate this issue (using AVG) with your site. May I ask is the issue present when using one of the default Joomla templates (Protostar)?
No, I use your template "Revolve". The problem also exists when calling your side joomla51.com. :ohmy: As is done the same virus warning. The last update of F-Secure ensures that ad. Other virus scanners are not so susceptible.
Can you avoid loading caption.js somehow? What this file is required within Joomla?
best regards
Sven
Joomla does not allow the option to disable the caption.js however there is a number of extensions which allow some JS control. One recommended option is... http://extensions.joomla.org/extension/js-css-control
Thank you for the link. I give it a try. The extensions of cubic Rubik are really good.
Best Regards
Sven
