1. Pappy
  4. Friday, 06 May 2016
4 things.
1. I need to display the hornav menu on tablet/landscape and larger.
2. I'm using the 2 column html code for the bottom logo/copyright area. I expected the right column to go below the left, on mobile devices, but it isn't. Wasn't sure if it should on an older template.
3. The contact page is displaying oddly. I am using sidebar and the main content area is not full width and looks like "Bottom module background" is filling the rest (yellow on right side)
4. When using mobile menu, it is cutting off the bottom of my logo.
If I use margin or padding for spacing, the "Bottom module background" appears in the space.
http://198.46.84.168/~darsonar/index.php/contact
1. To amend try adding the following to the Custom CSS field of your templates parameters...
@media only screen and (min-width: 767px) and (max-width: 1024px) {
#hornav {display:inline !important;}
.hornavmenumobile {display:none; z-index: 99; }
2. Unfortunately when divs are set to 100% width as these would be in this case on smaller screen devices, they will appear in the order that they are coded.
3./4. To resolve try adding the following to the Custom CSS field of your templates parameters...
.backgrounds #content_remainder {
display: none;
