1. Rayjak
  4. Sunday, 06 November 2016
Main Menu converted to module position and assigned to hornav. Footer menu converted to module position and footer menu unpublished. Main menu still in footer position on home page. http://writing4freedom.com/brett_richards825/index.php
Do you wish to hide your footer menu?
NO. I would like the main menu at top and the footer menu at the bottom. I converted the footer menu to a module position. The footer menu appears on all pages except the home page where the main menu still appeared. I converted the main menu to a module position and still the main menu appears in the footr position only on the home page. I unpublished the footr menu which make it disappear from all pages - but the main menu still appears in the footer position. I am trying to have the footer menu appear on all pages including the home page. Currently it appears on all pages except the home page. I have left it unpublished so you could see that the main menu is still in the footer position of the home page.
Hi Rayjak
It sounds like there is a separate template style applied to your homepage to which you have not applied these settings. If this is not the case may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
You are so correct! Thank you.
OK. I broke what you previously did. Ref #24131
You created a home page. Using this home page corrected the issue with the slideshow. However, it always displays the main menu in the footer. I need the footer menu in the footer which I can get by using the Default Template and not the newly created Homepage template.
Currently, the slideshow is working with the new Homepage template and the menu in the footer is the main menu and not the footer menu which appears on all other pages.
In the 'Menus' tab of your homepage template style you can edit what menu is displayed in the footer area.
