1. HighlandJ51
  4. Wednesday, 18 March 2015
Using the Virtuoso template in a 2.5 site, any page that has a sidecol (A or B) module enabled has the lower modules (base, footer, etc.) disappear and a large, overly deep white block in their place.
Please take a look at http://femalepelvicmed.com/ or http://philipanthonymd.com/ in regular mode and then in mobile mode (landscape or portrait).
In each case, the home page shows the problem, but any page without a sidecol is fine.
Thanks in advance
.backgrounds .sidecol_a, .backgrounds .sidecol_b {display:none !important;}
Thanks for the quick response... The problem remains, though.
I’ve attached a before/after screenshot showing the lower half of the home page full size and then mobile size. All other pages on the site that do not have a module published in the "sidecol a" or "sidecol b" positions do not exhibit this problem.
Thanks again!
Hi Ciarán -
The problem has been solved - replacing the responsive.css file with the one from the joomla 3 template version did the trick.
Thanks again for all your help!
