1. POE
  3. Thursday, 21 September 2023
what to do with the attached message we receive when starting the homepage (pilarz.consulting) . Is it a problem how we used the DemoInstaller?
The feedback from SEO indicates, that also the administrator panel is very slow. Please can you help!
Wolfgang
meanwhile there is an additional warning on other pages. There seems to be a loop. Is it in the template or created in our configuration?
We urgently need your support.
Merci, Wolfgang
Admittedly the issue does not appear to be related to your template. Are you getting similar issues on this server with the default Joomla installer (https://downloads.joomla.org/cms/joomla4)?
thanks for this hint. I only startet to install Layla on the server for another website http://www.kissgmbh.com
There I see no problems and there the numbers and progress module perform also - which do not work here.
What do you recommend?
Merci, Wolfgang
Hi Wolfgang
Could you try downloading the latest template and installing the attached Progress and Numbers modules. If this does not resolve the issue, may I suggest sending temporary administration access to your Joomla installation to [email protected] and we will examine this issue further. For our reference please paste a link to this post in your email.
there are two similar warnings - not only with the numbers module. I send you admin access.
Merci, Wolfgang
