1. green12
  3. Saturday, 06 February 2021
Do you have css code to reduce vertical space between modules on Sophia Template in responsive version.
thank you
Thanks a lot, it worked!:)
Edit to taste
@media only screen and ( max-width: 767px ) {
.module .module_surround,
.module_menu .module_surround {
padding-top: 10px;
padding-bottom: 10px;
Sorry, I saw that the distance has decreased between the Sidecol-1A and Sidecol-2A modules but not between the article and the Sidecol-1A module.
Is there a possibility to reduce this distance?
  1. https://www.gaiaguide.it/
For the side column modules you can also add the following...
.sidecol-a:first-of-type .module:first-of-type .module_surround,
.sidecol-b:first-of-type .module:first-of-type .module_surround {
padding-top: 20px;
.maincontent {
padding-bottom: 0;
