1. Eric_S
  3. Thursday, 23 November 2017
The bottom divs are too wide and I'm not able to find why. Please advise how to make the bottom the correct width.
Thanks.
div id="container_bottom1_modules"
div id="container_base"
http://summit-journey.org/images/Image 1.png
That would treat the symptom, not the cause. Fixed it by putting the image in the showcase position. Thanks.
Hi Eric
Could you please post a URL to an example of this issue.
The rest of the site appears correctly (not live yet, not publicly accessible).
Thank you.
Adding what? :)
To amend try adding the following to the Custom CSS field of your templates parameters (Extensions -> Templates -> [YourTemplateStyle] -> Custom CSS).
Opps... I'm an idiot :)
The CSS...
#container_bottom1_modules,
#container_base {
max-width: 1120px;
Thank you. That actually reversed the condition. Now the home page is correct and on all other pages (not live yet, not publicly accessible) the bottom is too narrow. :(
Hi Eric
One option is to create a new template style to which you can add the above CSS. You can then apply that template style to just the effected menu item (https://www.joomla51.com/tutorials/item/creating-multiple-template-styles).
I have narrowed the problem down to the breadcrumb position. When I activate the breadcrumb in the breadcrumb position the bottom becomes too wide.
Hi Eric
I sent you a login.
The problem is that div id="container_main" ends up inside div id="container_top3_modules" when the breadcrumbs module position is activated. I believe the closing /div tag for div id="container_top3_modules" is misplaced.
Thank you Eric
We have just resolved this issue in the latest download of the template. To update your template to the latest download may I suggest the following article.. https://www.joomla51.com/tutorials/item/updating-your-template
Confirmed. Thank you.
