1. skipper
  3. Wednesday, 04 March 2015
Hallo Ciaran,
how are you? I checked an index.php with validator w3 and found 27 errors and 2 warnings..
5 of them are caused by googleapis, so no worries but Validator only shows lines as per index.html, not index.php of course. How can I create an index.html to find the errors and correct them?
URL http://www.willers-willers.de
Best Regards and Thanks for assistance
skipper
Hi Skipper
Sorry to say converting your site to HTML will not assist in finding the source of the errors.
Having a quick look I notice all of your errors can be fixed by installing the latest download of your template. Simply re download your template and install via your Extensions Manager to update. Please note that all core template files will be replaced so be sure to backup your template if any changes have been made.
