1. sdoratti
  3. Wednesday, 05 April 2017
Hi there Ciaran,
In the demo of the Valencia template, the slideshow on the homepage shows text on the bottom right, but when I use this template slideshow it is showing the text in the centre of the photos. With the site I am using it on, bottom right would work best.
Thoughts?
Thanks so much,
Sherri
Hi Sherri
Would you have a URL to an example of this issue? Have you installed the module bundled with your template download?
I installed the module that was bundled with the template Valencia download, and used it briefly on http://desertenglishsetters.com/ I was hoping to see how it worked with the photos that I had on the homepage (although they need to be resized, as the site is currently running the Calibri template), as I liked the concept. I was going to change up Calibri for Valencia, but not until I saw if I liked the first page, or, if it worked fine and looked fine with Calibri and some modifications to the side menu and other modules, I would leave it running. Since it ran the text in the middle of the page and the effect was not at all what I'd hoped for, I unpublished it and put up the J51 slideshow it was running previously.
In my limited experience, I thought it was possible that this slideshow would run as demo'd as it is an independent module, and when it didn't, I thought I would ask. Does it have to be run with Valencia to position the text as demo'd?
Thanks for your patience, and feedback,
Sherri
Hi Sherri
Thank you Ciaran, I have installed Valencia together with the slideshow and it works together properly.
Great products!
