1. POE
  2. Pre-Sales Question
  3. Friday, 18 August 2023
I have already installed Joomla 4.0 on my web host's server with Cassiopeia as the default template. How is it possible to install the template demo content, such as from the Layla template for example, so that I can quickly adopt and edit the one-page template?
May I suggest the following article on this topic.. https://www.joomla51.com/tutorials/demo-installer/setting-up-the-demo-installer
Merci Ciaran, I had read this tutorial what gave me the impression, that it is not planned to install your Templates after Joomla4.0.
But I tried and did upload the whole 46 MB zip file.But now I received two messages:
JInstaller.: Install: XML-Installation-file could not be found.
Manifest-data set could not be found.
Where do I find these files? Is it necessary to unzip them before uploading? Or...?
Ciao Wolfgang
Meanwhile I went the long way, unzipped your Layla Demoinstaller and uploaded all files to the MySQl database, where Joomla 4 and the Layla template were already installed. Now I see on frontend "Layla Home" but not the Demo version with the sample data with the design I would like to use. How to change ?
  3. # 3
It looks like you are trying to install Joomla into a folder called "J51_Layla_DemoInstaller". If this is the case then open this folder in your browser (eg. http://www.yoursite.com/J51_Layla_DemoInstaller) to start your Joomla installation.
  3. # 4
Merci Ciaran, problem is solved!
Now appear in two positions with icons (top-3 and bottom-1a) and also in the main ("welcome to Layla";):
Deprecated: htmlspecialchars(): Passing null to parameter #1 ($string) of type string is deprecated in....
and Unable to find a user with the ID: 842 . That´s not me.
How can I get rid of these?!
Ciao, Wolfgang
  3. # 5
  3. # 6
I did send you all administrator accesses (ftp, MySQL, Site) 5 days ago and finished my adoption of the Layla-layout.
I neither need the progress bar nor the icons, but a clear homepage. Is it possible to clear the problem in top3 or should I better switch off this row?
Or is it a deeper problem and I better use another template?
What´s the best?
Ciao Wolfgang
  3. # 7
Thank you Wolfgang
  3. # 8
Thank you Ciaran,
it works well, looks nice and there are no further problems. Now I nearly finished all my adoptions of the template.
So I need to clean and prepare my website for SEO. My question is, do you (J51) provide such a service like a technical SEO check with adoptions and how much would it be for a website like mine?
Wolfgang
  3. # 9
Hi Wolfgang
Thank you for considering us, however, I am sorry to say that this is a service we do not currently provide.
  3. # 10
