Just curious, it is okay to use extensions from different templates in your current template? Will the effect be the same? For example, I like the carousel from Stockholm Template package, and I want to use it in the Central Template. I will obviously be uninstalling the existing carousel that came in the Central template package and then install the carousel extension from the Stockholm Template.
Thanks,
KK
