I am building a website located at http://heatleycapital.net using the Habitat Template.
I am using a Blank Component in order to display the homepage as a HTML Module which is working perfectly, however, it is displaying a white band below the module showing the blank content component.
Is there an if then CSS command that I can use to remove that from the homepage only and not interfere with any of the other pages?
Any assistance you can provide will be appreciated.
James
